Interior Lighting
Old Sep 27, 2016 | 11:08 AM
lzarc1's Avatar
Default Interior Lighting
My interior lighting comes on briefly when door is open, then go off, does anyone have any idea of why this happens?
Thanks for any suggestions
Old Sep 28, 2016 | 11:42 AM
avern1's Avatar
The interior lighting comes on when the door is open and after an interval if the door is left open the lighting will shut off. If yours is going off before you have had a chance to be seated and inserting the key then it is probably going off to soon.
The control of the lighting I think is in the SCLM (security control locking) module. The module is located beneath the fuse box in the boot. Due to it's position it occasionally can get wet and corrode.
I would remove and unplug the module and thoroughly clean the contacts on the module and the connector with contact cleaner. High resistance from corrosion could be the problem. You can apply di-lectric grease to the connector.
You might want to also disconnect and clean the BCM (body control module).
MAKE SURE TO DISCONNECT THE BATTERY BEFORE WORKING WITH ANY MODULE.
mrplow58
Oct 17, 2016 05:55 PM
jeffwilson34
Sep 29, 2016 02:27 PM
Johnken
Sep 29, 2016 09:12 AM
Enderwiggin
Sep 27, 2016 01:33 PM
Rjscharer
Sep 24, 2016 05:03 PM
