Interior trunk release button backlight
Old Nov 4, 2017 | 12:41 AM
ericjansen's Avatar
Default Interior trunk release button backlight
Having my friend's car for some days, I noticed I missed one back-light in my own interior when I replaced all bulbs.
But how can I remove this unit, is it a matter of pulling harder, or do I miss something?
Old Nov 4, 2017 | 04:31 AM
Stu 1986's Avatar
It does pop out, you can reach it easier by removing the coin tray and pushing it from behind. Be aware that the interior temperature sensor is attached to this by a rubber tube which can be troublesome to refit, and the plug(s) attached to the switch have very little travel so you're best removing them via the coin tray hole. The coin tray is held in by a single Phillips screw. Use the opportunity to clean the temperature sensor too, it looks like a MAF sensor.
The bulb is the same as in all the other switches.
Old Nov 4, 2017 | 04:48 AM
ericjansen's Avatar
Thanks Stu.
Of course you should have reacted an hour earlier, but I forgive you
Seriously, thanks, nice little project for tomorrow's rainy Sunday.
EDIT: The removal of the coin tray did the trick, and one can actually just slide the button part out, that leaves the interior temp sensor in place (which is working fine for me).
Muchas Gracias Again!
Old Nov 4, 2017 | 05:52 AM
Stu 1986's Avatar
No bother Eric, I like the easy ones The coin tray I've never used for coins, I normally keep a microfibre duster in there for the interior.
The UK cars have an additional switch in that area for the headlight levelling.
Old Nov 6, 2017 | 05:39 PM
smith356's Avatar
what type of bulb is the replacement ?
thanks, Jim
Old Nov 6, 2017 | 05:46 PM
ericjansen's Avatar
The usual dash fitting (the larger of the 2 used all around your car), available from Jaguar and some Jaguar part suppliers, not cheap though.
I managed to find the bulbs in the right wattage, and make them myself, using the plastic fitting.
Works like a charm.
Old Nov 6, 2017 | 06:31 PM
smith356's Avatar
Great stuff ! Thanks, Eric
Old Nov 6, 2017 | 06:35 PM
smith356's Avatar
Missed that !
Old Nov 6, 2017 | 06:46 PM
ericjansen's Avatar
As mentioned, I missed this one initially.
All other switches and buttons have back-light, besides of the mirror selection switch on the driver-door, and the steering wheel buttons.
Old Dec 4, 2017 | 09:00 AM
dneider's Avatar
I just replaced the bulb in the trunk switch with two different known good bulbs, but mine never lights ups. Can anyone confirm that their trunk switch actually lights up.
Old Dec 4, 2017 | 05:48 PM
ericjansen's Avatar
Yes, they do.
Old Oct 10, 2018 | 11:26 AM
King Charles's Avatar
It's been a while since I did my other switch bulbs but what bulb # was the trunk release again as mine's out as well.
Old Oct 10, 2018 | 05:19 PM
ericjansen's Avatar
Post #6 is all I can help you with.
Old Oct 10, 2018 | 05:27 PM
Image search gives me LNA5180CA, is that correct sir ?!
https://www.motorcarsltd.com/lna5180ca.html
Old Oct 10, 2018 | 07:45 PM
ericjansen's Avatar
That base should be ok, but I am not sure on the wattage / intensity, as mentioned, I went the replacement bulb-way.
Old Oct 10, 2018 | 08:09 PM
Man you truly know something's over engineered when tasks as trivial as changing vanity bulbs takes vast research lol. I had to go through 3 vintage Jag parts' dealers to confirm what bulbs the driver's side switch pack took. Finally got to the bottom of it though.
X308 never a dull task lol !
