Jaguar VDP, I thought we were friends? CEL and 6 codes!
Old Mar 29, 2011 | 06:18 PM
burmaz's Avatar
Unhappy Jaguar VDP, I thought we were friends? CEL and 6 codes!
So last night I took a late night cruise in about 40 degree weather and drove rather gently. After about 15 mins, I pulled up to a stop light and my car had a rough idle out of nowhere and rough/surging acceleration. The car almost felt like it could stall at times (it didn't though).
The rough idle persisted until today and I had the codes read at autozone:
P0171
P0174
P1642
P0301
P1316
P1111- irrelevant
I think P0171 and 0174 are related to an intermittant restricted performance light that comes on when coasting around 50 mph for over 5 seconds, and then goes away after about 15 seconds. That has not triggered a CEL in the past. This has gone on for a bit. I tightened up everything on the intake and cleaned the throttle body connection and MAF sensor. I'm thinking the accordian in the intake pipe must have a small crack somewhere.
What would cause the CAN error code and a misfire code? The car was driving perfectly until all the sudden the roughness occured out of nowhere. The car is drivable, but sounds terrible and I don't feel that its trustworthy to drive around a lot in. Would driving the car damage anything (the cats, exhaust, and etc)? The engine makes a slight pressurized air woosh that changes with the RPM. (I'm guessing the misfire is causing a VERY slight backfire)
Any ideas as to what could be causing all this? I'm guessing a coil, but how would that have crapped out all of the sudden?
Old Mar 29, 2011 | 07:16 PM
test point's Avatar
One issue on these cars can cascade into other codes. The P0171/0174 is the obvious place to start. That issue could be causing the miss fire. Air leaks, as you identify, in the duct from the air filter to throttle body plus the full load breather tube and even a constricted part load breather tube.
Make all that go away and see what is left.
Old Mar 29, 2011 | 07:42 PM
dba-one's Avatar
A jag with problems? Say it isn't so. Since problems cascade as it was put You may end up spending money and time on crap that has nothing to do with the root cause. I've been telling folks that owning one of these is like having a supermodel for a girlfriend. Except she is dead.
Old Mar 29, 2011 | 08:13 PM
test point's Avatar
I love my car! Only two in the county and the other is a garage queen.
Old Mar 29, 2011 | 10:34 PM
burmaz's Avatar
HAHA!! That's a new one.
An intake problem with a 2 bank lean situation could lead to a single cylinder misfire? I will take a look at the intake again tommorow.
Old Mar 30, 2011 | 01:55 AM
plums's Avatar
Sure, because while the entire system is lean, there may be one cylinder that is more sensitive to a lean condition. For example, on some engines, specific cylinders are known to be the weak sisters in fuel charge because of intake runner layout.
Old Mar 30, 2011 | 08:01 AM
JimmyL's Avatar
Did they reset the codes at Autozone ? If the P0301 comes back, you could always swap the coils on cylinder 1 and 2 and see if the code changes to P0302. It helps to have a code reader. I got the P0171 and P0174 and restricted performance - it turned out to be a cracked/broken part load breather hose and I actually did this myself when cleaning the part load breather (unbeknownst at the time).
fast40driver
Apr 19, 2024 07:24 AM
philwarner
Dec 6, 2021 07:13 AM
Isoruku
Jun 19, 2020 12:54 PM
Jandreu
Aug 23, 2019 11:37 AM
Jandreu
Aug 29, 2015 07:31 PM
