Jaguar XJ8
Old Nov 30, 2014 | 02:39 PM
pekkas-1's Avatar
Default Jaguar XJ8
Can anyone say why I did not may change the display language, XJ8, 1998 at. I tried that maxim that put the ignition key to position II and press the ML / KM and you will get the current language, but I do not see anything at that point. The car has all the time the German language, I would like to change the English
What I?m doing wrong?
Old Nov 30, 2014 | 05:49 PM
motorcarman's Avatar
Keep pushing the Miles/KM button to scroll through the languages and stop on the one you want. Press the A/B button to lock in the selection.
bob gauff
Old Dec 3, 2014 | 07:51 AM
I read the post again and I did not mention that the Miles/KM button needs to be pressed before the key is turned ON (or at the same time).
Then scroll through the languages.
bob gauff
Old Dec 4, 2014 | 03:46 AM
pekkas-1's Avatar
I got it to work, so that the ignition key was set to 0, and then punched ml / km, and at the same time I put the ignition key to position II then became the language of your choice, that is, now also has been amended. Thank you for your help.
MarathonJohn
Sep 3, 2015 07:59 PM
plums
General Tech Help
Sep 1, 2015 06:34 AM
Will P
Aug 27, 2015 06:52 PM
Terencex
Aug 26, 2015 08:47 AM
souldoubt
Aug 25, 2015 08:15 PM
