Jaguar XJ8 3.2 Year 2000
Old May 19, 2008 | 10:47 AM
Thermo's Avatar
Veteran: Navy
Default RE: Jaguar XJ8 3.2 Year 2000
da1, first, check the mass air flow sensor to see if that is clean. If it gets dirty (or oily if you are using a cotton gauze/oiled filter), it can cause the motor to idle erratically. You simply let a little bit of electrical contact cleaner get near the sensor and it will clean it off. DON'T spray the sensor directly. It can break the sensitive wires inside of the MAF sensor.
Next, is the idle moving up and down a few hundred RPM also? If so, your idle air control valve can be sticking and leading to issues. Remove the idle air control valve and use some carb cleaner to get rid of the gunk inside.
After that, I would need to check my service CD for your car and see if there is something else that might poke its head up.
Chris "Thermo" Coleman
Old May 20, 2008 | 07:28 PM
FactoryJaguarTech's Avatar
Hardware or automotive parts store.
I would offer some suggestions, but we do not have 3.2 motor here. Maybe coils? Idle control valve as suggested sounds likely too.
Old May 21, 2008 | 11:01 AM
wdonovan's Avatar
ORIGINAL: FactoryJaguarTech
...Maybe coils?...
Bad coils almost never fire correctly under load.
Old May 21, 2008 | 07:15 PM
I beg to differ, but let us know how you make out anyway.
MJ'S Jag
Nov 10, 2022 08:14 AM
bjelliott
Sep 1, 2015 10:30 AM
nelsonht
Aug 30, 2015 06:01 AM
peterg19
Aug 28, 2015 08:42 AM
souldoubt
Aug 25, 2015 08:15 PM
