Jaguar XJR AJ27 running lean
Old Jun 16, 2017 | 08:19 AM
Maxville's Avatar
Default Jaguar XJR AJ27 running lean
Good day!
Right now i got a problem with my XJR AJ27
during my HU test (security check in Germany) my car was running so lean they wont give it a pass.
Lambda was at about 1.2xx, engine was at operation temp, rest of the values where perfect, cats work properly.
No codes and the car runs very good.
Mods done 7% smaller upper pulley, first and second resonators deleted.
My thoughts to solve the problem:
- change the fuel filter and check the fuel pressure
Do you have any additional ideas because of my problem and may the value for the fuel pressure?
Best regards out of Munich!
Maxi
Old Jun 16, 2017 | 09:15 AM
Sean B's Avatar
Max, running lean without codes is usually an unmetered air leak, either induction tube, throttle body gaskets or MAF - check them all.
Old Jun 16, 2017 | 09:24 AM
JagV8's Avatar
That's a terrible lambda!
See threads about watching fuel trims etc.
BTW it's not running OK. You just haven't been able to tell.
Old Jun 16, 2017 | 11:09 AM
Maxville's Avatar
Thanks for the advice, i will check the whole section.
JagV8 i'm sorry, i don't understand your statement
Because of what should i'm not able to tell?
Old Jun 16, 2017 | 05:27 PM
JagV8's Avatar
You said it's running very good. It isn't. You haven't noticed.
Old Jun 16, 2017 | 07:28 PM
Maxville's Avatar
Sorry, but i have the car now for about 9 years, just one owner before, now 103k km, the engine and transmission has just about 35k on it.
I know how the car was running at the beginning and the behavior hasnt changed over the years.
I'm very sensible for noises or uneven engine smoothness.
Another point, if it would run so bad 100-200 time is 14.6 sec on 25 C° outside temp, 80% fuel, 2 person inside, A/C off.
Messured with Vbox, no bridges, plain surface and no forest around.
Ever tested yours and got a time for me to compare?
Old Jun 17, 2017 | 01:26 AM
JagV8's Avatar
You won't notice things like bad fuel trims that are burning up cats. You won't notice typical misfires that do serious damage.
Neither of those typically affect what you posted.
Old Jul 26, 2017 | 06:52 AM
Maxville's Avatar
Good day everybody!
Sorry it took some time to test and do all the things based on your advice...
But after all there i no change, the car is still running lean.
So I decided to change the upstream sensors with Bosch 15627 pieces.
Do you have any idea where i could get them for a resonable price? Because here in Germany they charge over 300 € for them.
Maxi
Old Jul 26, 2017 | 07:16 AM
King Charles's Avatar
Originally Posted by Maxville
Good day everybody!
Maxi
BOSCH 15627 Oxygen (O2) Sensor | RockAuto
Amazon Amazon
