Just To Clarify the Appearance Difference in 3rd Generation Tensioners
Old Sep 26, 2013 | 07:26 AM
robertjag's Avatar
Default Just To Clarify the Appearance Difference in 3rd Generation Tensioners
I notice upon installation of the 3rd generation secondary tensioners that the right and left are not mirror images of each other.
At first I was concerned that the wrong part(s) were in the boxes. After the install I assumed that the new design just had the right and left tensioners designed differently from each other.
I just want to make sure before reassembling and start up.
The Driver's / Left side has the broader plastic surface area to the top and is spring-loaded at the top:
The Passenger's / Right side has the broader plastic surface at the bottom and is spring-loaded at the bottom:
Has anyone else noticed this?
Also, I do not know how anybody "primes" these tensioners with oil prior or after installation. Comments here?
Thanks.
Attached Thumbnails Just To Clarify the Appearance Difference in 3rd Generation Tensioners-1-robertjag-133241-albums-garage-cheshire-other-automotive-interests-6333-picture-left-drivers-2.jpg   Just To Clarify the Appearance Difference in 3rd Generation Tensioners-2-robertjag-133241-albums-garage-cheshire-other-automotive-interests-6333-picture-right-passange.jpg   Just To Clarify the Appearance Difference in 3rd Generation Tensioners-1-robertjag-133241-albums-garage-cheshire-other-automotive-interests-6333-picture-left-drivers-2.jpg   Just To Clarify the Appearance Difference in 3rd Generation Tensioners-2-robertjag-133241-albums-garage-cheshire-other-automotive-interests-6333-picture-right-passange.jpg
Old Sep 26, 2013 | 07:46 AM
WhiteXKR's Avatar
They are correct.
To prime them with oil you must remove the fuel injection (not fuel pump) relay and crank the engine for about 5-10 seconds.
Old Sep 26, 2013 | 06:18 PM
WaterDragon's Avatar
I used a syringe and injected the oil into the tensioner before installing them.
The advantages of being married to a MD.
Old Sep 26, 2013 | 10:21 PM
robertjag's Avatar
Default Fuel Pump vs. Fuel Injectors Relay?
Originally Posted by WhiteXKR
They are correct.
OK, so it's not the fuel pump relay (No. 4 in trunk of NA cars)?
So where is the fuel injector relay located and identified?
toronadomike
Jan 22, 2026 10:13 PM
Forcedair1
Sep 8, 2025 01:57 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
SeanU
Sep 11, 2015 12:56 PM
convincor
Sep 10, 2015 06:50 AM
