hose connector missing??
Old Sep 26, 2013 | 01:08 PM
John Tarantula's Avatar
Default hose connector missing??
had one (of the many) brittle plastic coolant hoses snap a while ago so replaced temoprarily with some rubber hoses and jubilee clips. Finally got a proper Jag hose to fix it and either i have the wrong hose or there is a connector missing - has been a while so can't remember if I took one off?
is the hose between the coolant filler tank and the large metal pipe that has the thermostat in above the pulleys and belts etc. Hope that makes sense!
If I am missing a connector anyone know the precise name or part number or I'll need to bodge it again!
Old Sep 27, 2013 | 09:56 AM
Highhorse's Avatar
Assuming this is a straight overhead view, that's a slip clip and your missing the base metal retainer for the plastic clip to hook to.
Old Sep 27, 2013 | 03:04 PM
thank you, yes that is from overhead. Looks like a trip to Jaguar in the morning then for the missing bit. cheers!
dsnyder586
Dec 29, 2024 07:39 PM
mhamilton
67
Apr 1, 2021 03:20 PM
HypnoGuru
Oct 23, 2018 09:53 AM
copyman01
Nov 1, 2015 01:01 PM
Lannyl81
Sep 19, 2015 08:07 PM
