just fixed my key fob!
Old Apr 2, 2010 | 10:01 AM
ricasso's Avatar
Default just fixed my key fob!
dont know if this might help someone else but my key fob for my '98 xj8 stopped working so I was having to lock up with the key.
I took it apart today to see what was goin' on inside,after splitting the cases I lifted out the circuit board and took off the rubber button pad, the contacts under the pad were covered in black grime so I soaked everything in contact cleaner,reassembled,and its been fine ever since.
Old Apr 2, 2010 | 11:59 AM
Sarc's Avatar
@ricasso
I did the same thing a while back and got an extended lease of life from mine, but it's starting to go again...... I read another post on here about using a "liquid" circuit board pen on the rubbery pads which you can get from Frys, so I'm going to try that next
Old Apr 2, 2010 | 01:09 PM
eaglexkr's Avatar
Wink Remotes
We all must have too much junk in our pockets I just had the same issues with the remote for my XKR ,see link.
https://www.jaguarforums.com/forum/s...271#post191271
Old Apr 2, 2010 | 04:20 PM
MidlifeXJR's Avatar
Default Another solution
I had a continuous problem with the key fobs from my late nineties Cadillac, and simply using the red rubber eraser from a #2 pencil will do the job. Simply clean the circuit board contact surface and the respective contact point on the rubber. This is a great way to deal with it when you are at the office and don't have the rubbing alchohol available.
Old Apr 3, 2010 | 08:18 PM
TehNam's Avatar
Good tip.
Old Apr 3, 2010 | 08:24 PM
Gus's Avatar
Gus
This might help http://www.gusglikas.com/AutoRepairxk8Remote.htm
Old Apr 4, 2010 | 10:26 AM
ricasso's Avatar
Originally Posted by Gus
thats it exactly Gus!,many thanks
peterg19
Feb 10, 2023 09:02 PM
Kylejones
Sep 13, 2015 04:36 AM
jfitzoz
Sep 7, 2015 04:28 AM
Rick Michael
Sep 6, 2015 06:53 PM
My Pham
Sep 4, 2015 03:37 PM
