just looking for the ball joints
Good day, gentlemen ( I am not sexist)
with the poor road condition in NY area. I need to replace the ball joints (both upper and lower). just want to know the best place/website to get the parts.
I wont get the entire control arm from the dealer, that is just killing me.
thanks
Vincent
thanks
Vincent
went on Amazon but couldn't find the exact matching parts.
I just spoke with my mechanic. I suggested me to get the whole new control arm.
here I have 2 questions
please help
- the whole control arm is never cheap but will that be will cost effective replacing the whole piece? consider I will have to pay less labor to my guy ?
- also on I am on partgeek.com they have both lower forward and lower rearward parts of the control arms. they are just too many related parts and I am lost.
please help
you have to grind the **** out of the ball joints to press it out. if your car is up north everything is gonna be rusted and hard to get off. buying a used control arm and pressing new stuff in before you start the job will reduce your downtime and labor if you're paying somebody.
upper
https://www.fcpeuro.com/products/jag...der-jlm021380l
lower
https://www.fcpeuro.com/products/jag...Lw_wcB#fitment
upper
lower
upper
lower
upper
lower
I would recommend against buying MTC control arms in case you've considered them, they have poor quality/durability, and the machining for the ball joint bore is so sloppy, conical, and oversized that a factory replacement lbj will just fall out by hand if you try to replace it after it wears. Can provide more details when I've got more time
hawaiiansurfster
Jan 1, 2013 07:13 AM
