key fob problems...
Old Feb 6, 2013 | 06:32 PM
Alan Foreman's Avatar
Default key fob problems...
locking the xj8 is becoming more of a problem, having to stand nearer and nearer the car. cells in the remotes have been changed, but still makes no difference, maybe this is a transducer problem???
p.s. i have to state that this forum is the best thing I've ever been on...more knowledge here than you can shake a stick at!!!!
Old Feb 6, 2013 | 06:52 PM
test point's Avatar
Welcome to the forum Alan!
There have been discussions on the antenna connection to the Security Locking Module causing problems. Thankfully, few failures of the module itself.
It is located under the fuse panel in the boot.
Try a search to bring up one or more of the threads.
Old Feb 6, 2013 | 10:59 PM
pod184's Avatar
Also check the circuit board on the remote itself, where the buttons press against the board. Use some electronics cleaner or alcohol and wipe down both the board and back of rubber buttons. You might find a blackend film on it . . . .
Let us know what you find!
Old Feb 7, 2013 | 12:11 AM
robertjag's Avatar
Pod is right on here.
philwarner
28
Jul 11, 2017 10:21 AM
redxk8
Sep 30, 2015 08:18 AM
Listers
Sep 30, 2015 07:45 AM
Jzar
Sep 27, 2015 02:55 PM
