key fob reprogram
Old Dec 31, 2012 | 10:47 AM
x300man's Avatar
Default key fob reprogram
does any one know how you program key fob after replacing batterys as "thicko" me that is , having problem doing so, thanks in advance all
Old Dec 31, 2012 | 02:53 PM
andrew lowe's Avatar
unlock car. hold indicator stalk in flash to pass mode. turn ignition key to position 1, flash headlamps 4 times. press lock button on remote 5 times[or if more than 1 remote 2 times on one 3 times on other, so total presses add up to 5] . turn off ignition take out key. shut door try the remote. may take a couple of goes it did on my 98 xjr. if this do not work try the same but with the drivers door open.
Old Jan 1, 2013 | 06:37 AM
x300man's Avatar
Default key fob
just tried that ,but no joy so wondering if fob is "tired" but will keep trying thanks any way
Old Jan 1, 2013 | 06:53 AM
x300man's Avatar
have tried suggestions given to me ,but to no avail now at a loss using key to open and close car is not a problem and it starts ok could fob be worn out?
Old Jan 1, 2013 | 07:10 AM
steveinfrance's Avatar
Obviously try a new battery in the fob (I now see you've done that already)
You have to follow the 'How To' instructions precisely regarding the driver's door or it won't work.
BTW I've merged your two threads - having two on the go is unproductive for you.
Old Jan 1, 2013 | 07:42 AM
just noticed your name, have you got x308 or x300 as the process is different
Old Jan 1, 2013 | 11:09 AM
x300man's Avatar
its a 308, sorry steveinfrance put it on twive by mistake
philwarner
28
Jul 11, 2017 10:21 AM
redxk8
Sep 30, 2015 08:18 AM
Listers
Sep 30, 2015 07:45 AM
Jzar
Sep 27, 2015 02:55 PM
