Keyless programming
Old Mar 25, 2008 | 04:47 PM
rscultho's Avatar
Default RE: Keyless programming
Try this thread...might work...
https://www.jaguarforums.com/m_40536/tm.htm
Old Mar 25, 2008 | 04:49 PM
rscultho's Avatar
And I am assuming you disconnected your battery to reset your computer after installing the new "box" in the trunk
Old Mar 25, 2008 | 05:56 PM
FactoryJaguarTech's Avatar
The module in the trunk is the security locking module. Operates rear lamps and the keyless entry. If you noticed, when you replaced it, you had to disconnect a coax cable from it. That is the antenna wire for the remotes.
Old Mar 25, 2008 | 08:30 PM
jag_genius's Avatar
usually the sercurity and locking module just needs a good old ford handshake . the remotes are saved in this module as well
NCJagman
Dec 24, 2015 05:13 PM
redxk8
Sep 30, 2015 08:18 AM
Jzar
Sep 27, 2015 02:55 PM
zdrapec
Sep 25, 2015 05:49 AM
