knocking when cold from engine
Old Dec 16, 2014 | 01:09 PM
rexrich007's Avatar
Default knocking when cold from engine
Hi, any advice please?
I have a 2001 xjr the engine is strong still pulls like a train uses no oil or fluids no smoke even on hard kick down in fact runs superb! However, when it's been stood for a day or more when I start it up there's a quiet knocking coming from the engine. This noise remains for about 60 seconds but gets quieter and quieter until it disappears entirely, almost as if it's taking too long for the oil to circulate? I have very little mechanical knowledge but I know this is the better steel lined engine so praying it's not a tensioners issue?
Old Dec 19, 2014 | 06:51 AM
Fraser Mitchell's Avatar
My money would be on the cam-chain tensioners, but it is difficult to diagnose without listening. What part of the engine is the noise coming from ? It could just be a bit of piston slap.
Old Dec 19, 2014 | 07:23 AM
Brutal's Avatar
Tensioners
Old Dec 19, 2014 | 07:57 AM
Originally Posted by rexrich007
Hi, any advice please? .........
Welcome to the rexrich007,
I've moved your question from General Tech Help to X308 forum. Members here with the same model will be able to help.
Old Dec 19, 2014 | 08:51 AM
RJ237's Avatar
Your tensioners are plastic body, but likely 2nd gen. which has a external spring to reduce the sound. There may be other issues, but that's the first problem to attack.
Old Dec 19, 2014 | 10:58 AM
XJR Pilot's Avatar
Check for split in EGR valve tube. It is a 6" stainless steel tube from exhaust manifold to EGR valve. Replacing this tube solved my problem. See my post regarding this subject. https://www.jaguarforums.com/forum/showthread.php?p=1123355#post1123355
Old Dec 19, 2014 | 08:38 PM
sparkenzap's Avatar
You have been warned! If you are not sure you have metal tensioners, then it is foolish to drive that car any more until you get the ypgraded units in there. Many folks are not lucky enough to get a warning!
Old Dec 19, 2014 | 08:51 PM
test point's Avatar
Originally Posted by sparkenzap
. . . then it is foolish to drive that car any more until you get the upgraded units in there.
. . . then it is foolish to START that car any more until you get the upgraded units in there.
Another thing to look for is oil pressure. Even as worthless as the dash gauge is if it doesn't come to mid range in 2-3 seconds you probably have installed an oil filter without a check valve.
Old Dec 19, 2014 | 10:11 PM
Mark SF's Avatar
What dashboard gauge is that, exactly?
Old Dec 20, 2014 | 01:43 PM
Vector's Avatar
+1 on this.
A proper oil filter with a check valve would be the second thing I would check, right after the tensionsers.
But since you say it is a knock, not a rattle, I am guessing it is oil pressure related and a cheap oil filter without the proper anti-drain valve is probably the problem.
If you have a $5 "Fram" filter, take it off and throw in the nearest trash can and replace with a good one.
I use NAPA Gold filters, they are about $15 and they have all the proper parts.
Vector
Old Dec 20, 2014 | 02:07 PM
Vector's Avatar
Another thing to look for is oil pressure. Even as worthless as the dash gauge is.....
There is no oil pressure gauge in a 2001 XJR. Only an "idiot light" that tells you when you have ruined your engine.
Vector
SD96XJ6L
Jan 12, 2022 04:30 AM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
tberg
Sep 7, 2015 07:32 AM
Corycarlo
Sep 5, 2015 11:41 AM
robiwhan
Sep 4, 2015 10:43 AM
