Lighting troubles
Old Jul 23, 2020 | 05:02 PM
Allen Nelson's Avatar
Default Lighting troubles
I have a 1999 jaguar xj8 vanden plas. The park lights in the headlights and back park lights quit working. Can anyone help me?
Old Jul 23, 2020 | 05:11 PM
Welcome to the forums Allen,
I've moved your question from General Tech Help to X308 forum. Members here with the same model will be able to help.
Old Jul 23, 2020 | 06:21 PM
Highhorse's Avatar
Welcome Allen, first off you'll want to bookmark this site.... JagRepair.com - Jaguar Repair Information Resource
Then in the Site Search you can look up many things. In this case you'll want this more than likely... http://www.jagrepair.com/images/Auto.../jagxj1998.pdf ...you can download this also.
On Pg 54, figure 9.1 is the exterior lighting layout. I would look to find a commonality...I would highly recommend checking your grounds initially for corrosion and/or broken strap lug.
Everything is printable in that pdf.
At the top of every forum are Stickies for issues like TSB's, common problems and How To's. I have a link for 2 of those in my signature. There's also the JTIS download, which you may find favorable, if being as old as it is, if it will work with your computer.
Old Aug 7, 2020 | 09:54 AM
DonS's Avatar
Thank you so much Highhorse. As a new owner (and new member to this forum), I can not thank you enough for the jagrepair.com link. I found what I needed to start the diagnosis of my lighting problem.
Don
wrkeith1
Feb 18, 2020 07:05 PM
holybananas
Photography
May 2, 2016 08:07 PM
Rob56
Oct 3, 2013 01:05 PM
prarieboy
Oct 14, 2007 09:29 PM
