Likelihood of a Jag making it to 200k MI?
Old Jul 31, 2015 | 07:31 PM
Bcrary3's Avatar
Default Likelihood of a Jag making it to 200k MI?
Just out of curiosity, since my Jag is my daily driver, how many people have had their jags make it to 200k mi without replacing the engine or tranny or needing massive overhauls and $$$ repairs?
Old Jul 31, 2015 | 08:22 PM
sparkenzap's Avatar
Me! One MY 98 XJR started looking ugly at 220,000 miles, now "retired", One MY99 XJR at 185,000 (headgasket), and one MY 02 XJ8 with 178,000 looks and drives like new.
All run hard, abused and oil changed at nearly factory interval (10,000 miles).
That said, if I had been paying someone else to keep them running in top shape, I would be better to buy a new Jag (Oh yeah, I did!)
If are not sure your tensioners are changed, you better do them!
Old Jul 31, 2015 | 11:59 PM
Bcrary3's Avatar
I am almost positive they have been done, however not sure. One of these days I am going to take the valve cover off and just see if I can see if they are red or not, because then I know I have to do it rather than have to take it apart, oops it's been done, let's put it back together and return the parts.
That happened with my ball joints... Was going to replace the lower *****, but it's damn near impossible without a grinding wheel and or a new control arm!
Old Aug 1, 2015 | 05:15 AM
sparkenzap's Avatar
OK, but read the stories on here about folks waiting to get "A Round Tuit" for taking care of their tensioners, usually with words about "how well the car is running". The are all very sad tales indeed!
YOU HAVE BEEN WARNED!
The covers on these are not too hard to get off and it is a good time to carefully check the part load and full load breather tubes and to rod out the part load orifice. Getting the oil dip stick out of the way is about the main challenge in the process.
Old Aug 1, 2015 | 05:45 AM
rocklandjag's Avatar
"or needing massive overhauls and $$$ repairs? " = tensioners.
It is a lot harder to change the ball joints than to remove the valve covers
Old Aug 1, 2015 | 11:05 AM
dsnyder586's Avatar
One of many examples to choose from.....
https://www.jaguarforums.com/forum/x...g-chain-58559/
Old Aug 1, 2015 | 01:50 PM
bdboyle's Avatar
Default Depends
Getting 200k out of any car without ANY major hassles is a crap shoot. You can hear tales of cars going 200K with nary a peep...and others which seem to be hypercritical to regular service only to leave you stranded even if you follow the maintenance regularly.
I have an 80 VW Diesel Rabbit. Only repairs I did to it were a head gasket at 125K, injection pump at 175K, and a clutch at 200K. Finally gave it away with 325K to the VW dealer service manager...he drove it around for a couple more years.
I had a Caddy Seville with the northcrap engine in it that blew out the case half seal at 75K (luckily under extended service), a tranny at 90K, and a constantly plugged heater core (replaced once, which required the whole frapping interior be removed to get to it, again, under warranty) and barely made it to 100K before I traded it.
And don't ask about the 71 Lotus in my garage. That's a whole 'nother story.
Bottom line? It's a crap shoot. Rebuilding the tranny is not too bad if you ammortize it over 200K miles, replace the tensioners, heater hoses, plastic thermostat housing, etc. These cars are NOT garage queens, neither are they soulless toyohonnissans either. They DO require regular TLC. But if you do, I'm pretty sure 200K is well within the realm of possiblity.
Old Aug 1, 2015 | 02:30 PM
RJ237's Avatar
Motorcaman covered this one: Leave the dipstick in place and pull the tube out of the block a little and move it out of the way. The dipstick will guide it back in when finished.
Old Aug 1, 2015 | 07:16 PM
Lear45's Avatar
I am at 196,000, but not without expensive repairs...
Old Aug 1, 2015 | 08:04 PM
sparkenzap's Avatar
Yeah, but since the dipstick can stick a little, that is the challenge... And that is the ONLY challenge
Old Aug 3, 2015 | 05:18 PM
Bcrary3's Avatar
Roughly how long would it take to unbolt the valve covers?
I am guessing the passenger side would be easier as the dipstick is not in the way? Or can they ONLY be seen from the drivers side?
Old Aug 3, 2015 | 07:19 PM
I didn't remove the dip stick just removed the top bolt and pulled it away and strapped it out of the way. Be really careful of the breather hoses on each valve cover. they are brittle from the heat and split very easily.
Old Aug 6, 2015 | 09:43 AM
bdboyle's Avatar
$47.00 USD each. Did them both recently; previous ham-handed tech broke a lock tab on each of the disconnects and just used tywraps to keep them tight. Relatively cheap and easy to do. The heat does embrittle them, so, probably a good idea to just do it.
Old Aug 8, 2015 | 05:55 PM
IH60's Avatar
My '99 XJR is at 183,000 and running strong. Believe it or not, I bought it at 173,000 with the original secondary tensioners. Replaced those, valve cover gaskets (oil leaks), power steering pump, rear output shaft bearings (probably did not need those), tires, and am due for some shocks. All relatively low cost parts.
Old Aug 9, 2015 | 08:54 AM
Apocalyps's Avatar
1988 XJ8 made it to 225k mi before I finally retired it. Suspension bushings and driver-rear halfshaft bushings were the only "major" workings. It was my daily driver until the 1998.
1998 XJ8 is at 110k mi without any "major" workings aside from the warranty updates (e.g. throttle body, timing chain guides, etc) which were entirely done at no cost to me. It was my daily driver until motorcycle purchase. Now it is only used when it rains or trips to the grocer.
Old Aug 10, 2015 | 09:08 PM
kbeachy's Avatar
04 VDP purchased at 144k miles and now over 205k miles with no major problems. When this ones gives I'll certainly buy another of the same model.
Old Jul 10, 2018 | 01:28 PM
CharlzO's Avatar
Just want to add myself to the over-200k club, as of a couple weeks ago. 203k as of this morning, and aside from needing a TB rebuild in the worst way (P1121 can go suck a tailpipe...), it's still kicking.
Old Jul 10, 2018 | 01:47 PM
vincent661983's Avatar
My clock just turned 170k last weekend. But I have a book thick list of repair, up grades, modifications or rebuilds.
I guess it doesn't count
Old Jul 11, 2018 | 07:49 AM
chris-jag's Avatar
Default I'd say it's more than poss...
Over 200k
I've had this car only from around 190k. My thoughts are that if you're willing to get your own hands dirty then it'll keep going without burning holes in your pockets This forum is a life saver in that regard. Very worthwhile conducting your own inspections because some mechanics seem disinclined to take preventative measures. It's your pride n joy, not theirs I guess .
I find it a lot easier to work on than other cars too.
Old Jul 11, 2018 | 08:02 AM
p-Rock's Avatar
Theres a customer that goes to the shop with an 01 XJ8 with 388k. Thing has hit like 4 deers and been through a few trannies but man that engine just keeps going. Ill have to get a pic next time i see it.
