Listen to my engine
Clip is from a 2002 XK8 I just bought. My build date from engine stamp shows second generation tensioners. Posted on the XK8 sub-forum but same engine so posting here also. Listen for ticking after rev drops. Link below:
https://www.jaguarforums.com/forum/x...engine-281140/
I’d pull the valve covers and maybe use a bore scope to look at the chain guides down below. Another telltale would be to pull the oil pan and check for plastic pieces on the bottom and look inside the oil pickup screen.
Planning on that soon. Got a lot of around the house honey dos promised wife first. Few weekends from now I’ll report on the oil pan, pulling valve covers and bore scope results.
