Are LNC6195 and LJC6195 interchangeable?
Old Feb 28, 2010 | 06:35 PM
DavidB's Avatar
Default Are LNC6195 and LJC6195 interchangeable?
I need to replace the illuminated shift indicator--the ribbon connector that goes to the small LED circuit board has separated. That minor part actually communicates on the CAN bus and throws all sorts of scary messages when it's disconnected.
Ideally, I just need that circuit board, but is that available separately?
Assuming I need to replace the entire assembly, my existing part is LNC-6195. I've found LJA-6195 (thread title has wrong part number) which looks identical except it's marked for the non-supercharged car (my car is supercharged).
Are these two shift assemblies interchangeable?
Thanks,
David
Joachim1167
Nov 7, 2020 09:18 PM
X308XJR
May 20, 2019 06:50 PM
mrplow58
Sep 24, 2015 08:05 PM
jag79
Sep 21, 2015 05:58 PM
MHF25
Sep 13, 2015 05:24 AM
