Looking to buy SLCM for '98 XJ8
Old Oct 8, 2016 | 12:42 PM
3timejag's Avatar
Default Looking to buy SLCM for '98 XJ8
I am looking at eBay for one of these and I have found different model numbers. Can anyone tell me which is correct? HF, HD, etc... my VIN number is in my signature below.
MANY, MANY THANKS!!!!
LNC2600HF
LNC2600HD
LNC2600HF
LNC2600HE
Old Oct 8, 2016 | 03:09 PM
Rpach10115's Avatar
Here's what I did:
Open the trunk
Open the battery cover under the trunk floor.
You will see the battery and a large fuse box.
The SLCM is under there.
You. Should be able to see your code number when you remove the fuse box cover.
It's at the bottom of the fuse box.
If not, Disconnect the battery.
Remove the 3 bolts holding the fuse box to the floor and lift out the fuse box carefully. Turn the fuse box over.
The SLCM snaps out of the bottom of the fuse box.
Be careful as there are 3 connections going into the SLCM.
Go on eBay and type in the code you see on the SLCM.
It seems this is a popular item on eBay.
Swap the new one in when you get it.
mhessen6
Oct 12, 2016 05:37 PM
SeanU
Oct 7, 2016 04:45 PM
Daim
Oct 6, 2016 04:50 PM
Chris perryman
Oct 2, 2016 09:01 PM
sunchip
Sep 29, 2016 01:10 PM
