heater valve
Old Oct 7, 2016 | 07:27 PM
reds's Avatar
Default heater valve
Does anyone know if this part will work on a xj8/xjr. Variable Restrictor Valve Dorman 902-008 instead of buying the whole assembly. I seen it posted on the site but no one has said if it works. All help is appreciated.http://www.autozone.com/cooling-heat...?checkfit=true
Old Oct 7, 2016 | 07:28 PM
reds's Avatar
Old Oct 7, 2016 | 08:11 PM
Highhorse's Avatar
Is this what your looking for....https://www.jaguarforums.com/forum/x...nt-hose-75681/
Old Oct 8, 2016 | 08:06 AM
reds's Avatar
Default heater vale
its part #MNC6733AE but my hoses are fine just need that valve which jaguar does not sell.
Old Oct 8, 2016 | 08:31 AM
avern1's Avatar
Below is a link to JAGBITS one of the forum sponsors. They list in stock both a new and a used heater valve. The also have a picture of it you can use to compare. You might also want to check with SNG Barratt another sponsor.
Jaguar Parts - Jaguar Heater Valve
Old Oct 8, 2016 | 01:58 PM
yeldogt's Avatar
You may be confusing the connector with a valve -- part of the octopus is with the engine and the other with the body. They snap together when the engine was installed in the car.
The heater valve has an electrical connector as does the pump for the system
Old Oct 9, 2016 | 04:30 AM
xjay8's Avatar
Originally Posted by reds
Does anyone know if this part will work on a xj8/xjr. Variable Restrictor Valve Dorman 902-008 instead of buying the whole assembly. I seen it posted on the site but no one has said if it works. All help is appreciated.Dorman Heater Control Valve 902-008- ReadReviews onDorman #902-008
If you are referring to the one way inline valves (of which there are two)
they should work fine....jut remember to put them in right way round ;o)
Old Oct 9, 2016 | 09:13 AM
reds's Avatar
Yes xjay8 that is exactly what I am talking about and there are two but they are the same part. I'm just going to order the part and hope it works and I'll make sure I put the arrows the right way.
skinnypuppy_22
Nov 5, 2016 09:51 PM
mhessen6
Oct 12, 2016 05:37 PM
MickJagguar
Oct 4, 2016 04:26 PM
Serlock
Oct 3, 2016 10:54 AM
sherbercars
Oct 2, 2016 04:26 PM
