Looking for the location of auxillary power socket plug for C2A1403
Hi,
today I tried to install the auxiliary power socket inside the glovebox. But I cannot find the location of the needed plug on an LHD 2000 XJ8. Regarding the installation manual, it must be somewhere behind the glove box. I have only found a white one pin plug. But no 3 pin plug like the one needed for the original cable provided with the C2A1403 set.
Has anyone a hint where behind the glove box the plug is located in an X308 XJ?
I finally found the port. According to the factory wiring diagram, it is under the RH heelboard. This does not fit the instructions contained in the package which are for XJ > '98.
The instructions are for later models. 1998 wiring diagram states "RH heelboard", 2001 states "RH A post". The change was done at some point between the mentioned years.
