Looking for Spot to Mount Toggle Switches
Old Aug 10, 2011 | 07:54 PM
plums's Avatar
Default Looking for Spot to Mount Toggle Switches
What spots have enough clearance space behind the front surface to accomodate some small toggle switches?
The switch body is 1/2" deep by 1/2" high and 1/2'" wide.
The places under consideration are:
- main instument panel veneer at top right above trip computer switches
- j-gate veneer at top right above j-gate finisher
- center dash vent veneer at lower left (but seems like this requires adjacent veneers to be removed first)
The fallback position is the lip under the console lid where others have been mounting antenna power override swiches.
And ... any relevant advice about modifying wiring at the BPM harness/connector would be welcome
Old Aug 10, 2011 | 09:01 PM
dsnyder586's Avatar
I put the switch to change between CD and Bluetooth music under the armrest where the XJ6's used to have a valet switch...
Old Aug 10, 2011 | 09:06 PM
plums's Avatar
Thanks, that's the fallback position mentioned in the last bit of the post.
But, chrome toggles on wood are so pretty
Old Aug 11, 2011 | 02:56 AM
Sean B's Avatar
I'd go the ski slope route, there is just enough room to drop two in there, either side of the gear selector. Here's a picture of two switches I installed. (My interior is a work in progress by the way.....)
Attached Thumbnails Looking for Spot to Mount Toggle Switches-dscf5487-large-.jpg
Old Aug 11, 2011 | 04:13 AM
plums's Avatar
It may be in progress .. but it's pretty nice
The slope was one of the locations. Pretty tight for two switches to one side though. One side or the other is where a little custard dish sits as a make-do ashtray.
Now that the whole works is open, it seems that the bit just behind the cruise and sport buttons would be easier because it requires less surgery on the under support.
Now ... is there room for the micro-toggles to sit in the black gate that directly surrounds the shift lever? The area of interest is at the top between the "P" position and the shifter interlock over ride port. Is there a LED that sits in the way in the centre? (sorry to ask, but battery is disconnected and cannot be reconnected while the BCM harness is disconnected). JTIS definitely shows the disc from the shift indicator, but I am hoping that there might be just a bit of room left over.
Harness building starts tomorrow ...
Old Aug 11, 2011 | 09:20 AM
dsnyder586's Avatar
Thinking about it now, the spot below the cruise/sport buttons is a good one- that is where the wood tends to crack and the switch would provide some cover for that...
Old Aug 11, 2011 | 10:37 AM
plums's Avatar
ouch
Already have to fix both bottom corners of the glove box from following JTIS instead of doing it the normal way ... actually looking to find all screws like the last time.
And that's in addition to the 4 or so plastic retaining pins that were just flopping around under the j-gate finisher.
Most model car kits use better plastic than Jaguar.
Rivguy
Nov 13, 2022 02:55 AM
neckstrap
US Western
Sep 10, 2015 10:44 PM
1964Daimler
Sep 9, 2015 11:28 AM
laserguy
Sep 3, 2015 02:02 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
