Looks like I need timing chain work. URGENT ADVICE NEEDED
Old Apr 10, 2011 | 12:36 PM
  #141
chinny4290's Avatar
Canceling it.
Old Apr 12, 2011 | 02:21 PM
  #142
chinny4290's Avatar
Update. Unfortunately the problem still remains to be a rod knock because my flex plate/fly wheel was perfectly ok
Old Oct 22, 2011 | 09:41 PM
  #143
Spillwaybob's Avatar
The lubrication system of all modern cars has a screen on the oil pump pick up in the sump and the spin on oil filter would both prevent any metal pieces floating around in the sump from getting into the drilled oil pressure passages in the crankshaft. Rod or main bearing failure is mostly caused by oil starvation. This condition could have been caused by the previous owner(s). If there was no knocking noise at idle, then I would rule out bearing failure.
xjrjag
Nov 27, 2025 09:16 AM
lobsterD90
Nov 12, 2022 09:51 PM
celticpiping
Sep 18, 2015 06:17 PM
Bcrary3
Sep 12, 2015 08:43 AM
souldoubt
Aug 25, 2015 08:15 PM
