Loose timing chain normal?
Hi guys just pulled the 4 guide and 2 primary tensioner installed new one , but when rotating the crankshaft the primary chain are little loose is that normal ? And does it becomes tight after start the engine ?
Thanks .
Thanks .
Piston on guide yes . Bank A main chain looks good but bank B slightly loose . Im not sure once pressure builds up in the tensioner the chains will be tighter?
Just Discovered Its stretched timing chain but used it it works fine now no misfiring or rough idle
