Lost a circlip - not available anymore
Old Apr 15, 2017 | 06:57 AM
Daim's Avatar
Default Lost a circlip - not available anymore
Hey guys,
in an awkward moment if idiocy I lost a circlip in the garage. I can't find it and presume I'd only get it, if I get another one... Like when you lose the 10 mm soxket and end up buying another one. It magically appears out of nowhere.
Does anyone have just ONE circlip from the throttle connector rods? It sits either on the lower shaft, which pivots in the rubber bush or it is on the arm above that (for example the arm which actuates the tick over/idle switch). About 10-12 mm diameter, very flimsy piece of metal.
Anyone got one they don't need? This is buggering my adjustments up...
Damien
Old Apr 15, 2017 | 06:58 AM
Daim's Avatar
Sorry, wrong section. Thought I was in the XJ-S area... Mea Culpa!
