Low brake pedal 98 xjr
Old Jul 28, 2014 | 09:33 PM
smith356's Avatar
Default Low brake pedal 98 xjr
The car seems to stop fine, but pedal makes me uncomfortable with how low it is - would this be pad related ? Brake fluid is to top. Thanks, Jim
Old Jul 29, 2014 | 07:10 AM
Sean B's Avatar
pads, possibly. Have you checked how much material are on them?
Old Jul 29, 2014 | 09:38 AM
smith356's Avatar
Default pads
Sean, no, I haven't done that yet - I'm gathering info so that I can do wheel sensors and any other areas needing attention while wheels are off. Thanks, Jim
Old Jul 29, 2014 | 05:32 PM
D. Fite's Avatar
I asked the same question a few months ago after replacing my front and rear pads. Still had a lot of travel. Most replies stated that it was normal. One said you needed to rotate the caliper so the bleed valve was at top to bleed. Haven't tried it yet but I would like some more feedback on this myself. Very interesting. By the way I had an Allante and loved it. Like to get another but wife thinks I have enough.
Dave
Old Jul 29, 2014 | 06:05 PM
smith356's Avatar
Dave
I agree, Dave... it would be good hear from others on this topic.
[ I'm sure that T-Bird makes up for your loss]
Old Jul 29, 2014 | 06:37 PM
Sean B's Avatar
The caliper requires rotating when the pedal is that bad you can bottom it. This is a classic spongy pedal, usually after bleeding the system. It only take a few small bubbles to get this issue.
Even vac/pressurized lines cannot get this trapped air in the front caliper. When I first discovered this and shared it, it was doubted until people found it worked.
I removed the caliper and used wire to hang it with the bleed nipple (already backed off) with bleed tube and bottle attached pointing 12, once I opened the nipple bubbles showed - I let the fluid run clear and tightened up. Once the calipers are done the pedal is as it should be, unless there's a vac servo line leak, warn pads/discs etc!
Brembo equipped cars don't have this issue. Only ATE systems suffer this.
Hope this helps
Old Jul 29, 2014 | 10:10 PM
NJ2003XJ8's Avatar
Does the pedal travel too much before brakes grab or it simply stays low with little travel left?
If it travels too much, what happens if you press brakes few times - does that shorten the travel? If it does - the system most likely has something soft in it. Could be air, bleeding the system should help. I would do bleeding with assistant, not just letting the fluid drip out. Could be rubber hoses giving up, those should be replaces at some point(every 40K?) and I had issues with them on two cars I owned.
If pedal stays low, it could be some mechanical issue in pedal attachment.
The pads is the last thing I would look at, even if they are completely used-up it does not increase caliper's braking movement.
hope you sort it out soon, I would be scared to drive these heavy cars with any brake problems.
Old Jul 30, 2014 | 10:07 AM
smith356's Avatar
Hope this helps
Sean, thanks for this post. I'll definitely give it a go...Much appreciated !
Old Jul 30, 2014 | 10:37 AM
smith356's Avatar
Pedal travel is lower than my other vehicles, but just a concern - I like to feel the brakes right away. I'll look into new hoses - good advice. Thanks for your help, Jim
Forcedair1
Sep 8, 2025 01:57 PM
PMKimpton
Aug 3, 2019 08:22 PM
redrover41
23
Sep 25, 2015 01:33 PM
motorhead69
Sep 9, 2015 10:04 AM
