Lumpy running.???
Old Mar 5, 2015 | 04:57 AM
Heliwilly's Avatar
Default Lumpy running.???
I have been doing a few bits of work on my Dec 2001 XJ8 4.0. Last job before a 300 mile round trip, was to replace leaking cam cover gaskets. All went OK and no more leaks. After getting back I parked the car outside to unload the luggage. An hour later I went out to put it in the garage and on starting, it sounded to be running a bit lumpy. Blipping the throttle didn't clear things. It could be plugs, ign coil, injector. I cleaned the MAF sensor this morning and it made no difference, it wasn't dirty. I find that if I depress the throttle pedal slowly, it will rev up as cleanly. If I quickly blip the throttle, it sounds like I am getting a backfire in the exhaust. I am trying to get hold of an OBD tester to see if and codes are present. If anyone can help I would appreciate it. Thanks Bill W.
Old Mar 5, 2015 | 07:04 AM
rocklandjag's Avatar
sounds like you have a air leak. Check your part load breathers on each side and the intake tube and connections
Old Mar 5, 2015 | 11:38 AM
Jhartz's Avatar
+1 rlj's comments. Double check the connections from airbox to throttle body. Also clean the throttle bore and plate (carefully). Run some good quality fuel system cleaner through a tank (SeaFoam or Gamout's look alike).
Dirty connector, air leak, dirty throttle, most likely. But an OBDII readout for fault codes would id misfires.
Bigvettefreak
Sep 29, 2015 04:13 PM
abonano
25
Sep 25, 2015 10:43 AM
Iain Yates
Sep 16, 2015 06:48 PM
Shaggy9212
XJ40 ( XJ81 )
Sep 14, 2015 08:08 PM
Charlene n John
Sep 14, 2015 10:08 AM
