Mass Airflow NO NO
Old Aug 24, 2017 | 12:00 AM
2001xj8's Avatar
Default Mass Airflow NO NO
My 2001 XJ8 won't start or run unless the MAF sensor is unplugged. Do I need a new sensor or could it be almost anything?
Old Aug 24, 2017 | 06:23 AM
the_driller's Avatar
Get the codes read before you change anything.
Old Aug 26, 2017 | 10:07 PM
Don B's Avatar
Hi 2001XJ8,
Welcome to the Jaguar Forums! It's great to have you with us.
I have moved your thread from the forum for the X350 to the forum for the X308, which is the Jaguar factory project code for your 2001 XJ8. Here you will find knowledgeable owners of similar cars.
Cheers,
Don
Old Aug 26, 2017 | 10:47 PM
CharlzO's Avatar
Double check the wiring, to make sure something isn't shorted or broken. I had an issue that way when I accidentally pinched the harness in the darkened garage when I replaced my upper shock mount.
