master key locked in trunk - how can i open trunk now? + RESOLVED
Old May 23, 2022 | 03:04 PM
  #41
leaddog11's Avatar
Originally Posted by jimlombardi
Hi Ken
Good work finding that forum thread ("Any possible way to get the trunk open?").
Since the thread is almost one year old and has 20 postings in it, I though it might be helpful to include a copy of Forum member newuser post# 20 in the thread:
"Just remove the license plate and using a flash light look through the upper screw hole to locate where the latch mechanism is and once you see where it is, stick a semi long thin flat head screw driver through the hole and gently poke the mechanism where you see a small metal tab and it'll pop open."
And the other earlier one by newuser post# 15:
"I got it open in less than 2 minutes with the method suggested above by Gus. All I used was a long thin flat head screw driver and a a flash light to see through the hole and locate the latch mechanism. With the screw driver I lightly pushed on a small metal tab and the trunk popped right open and the valet mode was disabled (no need to disconnect battery). Hope this helps those with the same trunk issue."
I am sure these 2 posts will be helpful to others that find themselves in this same situation.
Thank you Ken for finding the thread.
Jim Lombardi
great to know. Thanks
Old May 23, 2022 | 06:17 PM
  #42
RandyS's Avatar
XJ8 sedans do NOT have convertible tops!!!!!!!
You are absolutely right! Sometimes I refer to my "top" being down when the sun roof is open.
This lady has an XK8, and may not have realized the instructions were for XJ8s
Old May 23, 2022 | 07:30 PM
  #43
Addicted2boost's Avatar
RandyS
Seven years too late to help that member out.
dsnyder586
Dec 29, 2024 07:39 PM
99xk8guy
May 28, 2024 09:36 PM
kevinl
Oct 31, 2019 06:15 PM
XJsc-guy
Nov 23, 2015 01:56 PM
Jay48
Sep 7, 2015 09:30 PM
