My jag gurgling under sudden acceleration
Old Jul 17, 2024 | 07:02 PM
Silverjag0's Avatar
Default My jag gurgling under sudden acceleration
It's been while I have this problem it only occur when I hit gas pedal hard like from zero to 40mph between 1to 3 rpm the car have like gurgling noise! Then after 3 rpm the car goes smooth and fast . I'm planning to replace the spark plugs and spark plugs seal and pulling the intake manifold to clean the injectors and the throttle body maybe also replacing the intake manifold gasket if it's not cracked I like to add some gasket maker and re install the manifold ,
I'm not sure if this will solve my issue any other ideas ?
Xj8 here not xjr
Old Jul 18, 2024 | 04:02 PM
Sean B's Avatar
Any warning lights flash up? It sounds like a misfire, but also transmission/torque converter - if you can plug in an OBD reader and see if there are fault codes logged, it's a lot faster than guessing.
Old Jul 18, 2024 | 04:29 PM
Silverjag0's Avatar
Obd shows nothing I had maf code month ago I cleaned it and deleted the code no misfire code or transmission codes thankfully . I highly believe it's the spark plug seal because I saw some oil around few spark plugs . Maybe clogged injectors gonna tune up the engine and see how it behave
Old Jul 24, 2024 | 08:08 AM
Silverjag0's Avatar
It was the fuel pump
VTGBoss
Jul 23, 2021 03:04 AM
car5car
Jan 23, 2019 07:02 AM
johnhdz21
Jun 26, 2012 12:32 AM
androulakis
16
Mar 31, 2010 01:31 PM
fclombino
Jun 1, 2009 08:30 AM
