At my wits end
Old Dec 20, 2010 | 04:57 PM
test point's Avatar
Both sides snap together with plastic 'fingers' much like a quick connect garden hose connector. Logic would say that should be able to be disconnected but my efforts have been unsuccessful up to the point of fearing breaking the plastic.
Old Dec 20, 2010 | 07:49 PM
Dan R's Avatar
The RH Norma connector has a locking collar which is slid forward to unlock the connector. In theory.
In practice, mine had become brittle with the heat and I ended up breaking it. Hence the splicing in of a length of heater hose using two connectors from the hardware store. I used water pump gasket cement on the mating surfaces. Works fine.
Old Dec 21, 2010 | 06:02 AM
pingj's Avatar
The left side comes apart easlily, with a 90 deg twist. The left side is the problem. I'm concerned about breaking it.
Does the piece of metal that comes off the engine have a plastic connector on the end?
The good news is the part are supposed to be in today and the dealer gave me the plastic fitting for the left side since they sold me the wrong part to begin with. With any luck the car will be back together tonight.
Old Dec 21, 2010 | 11:05 AM
H20boy's Avatar
IIRC, there is just a little lip on the end of the metal section of piping.
Old Dec 22, 2010 | 07:58 PM
pingj's Avatar
Finally got all the parts today. Too bad it was to late to do anything about it.
Old Dec 27, 2010 | 07:53 AM
pingj's Avatar
Finally after fighting parts and time I got the new part in.
I quit fighting the NORMA connector and just took my rotozip to the plastic connector. Cleaned up the bare pipe and the new connector slipped right on.
No Runs, No Drips,
NO HEAT.
Not sure what is causing the no heat. I partially disconnected the heater solenoid valve just to make it easier to work in the tight area. I think I got everything reconnected correctly. I will verify it tonight though.
Any other ideas on what the problem could be?
Old Dec 28, 2010 | 08:47 AM
DavidN's Avatar
Did you bleed the system completely?
I'm sure you'll find a how-to somewhere on this forum.
Good luck!
David
Old Dec 31, 2010 | 03:39 PM
  #28
pingj's Avatar
Good luck!
David
I wasn't able to find a specific procedure for bleading the system but this is what I did:
I cut off a long plastic funnel and used a rubber bushing to seal it to the fill tank.
I filled the system allowing it to drain the column of coolant down out of the funnel.
Once I had coolant dripping out of the overflow bottle I started the engine.
Turned the heat onto the highest setting with the fan on high speed.
Warmed the engine until the thermostat opened, all the while keeping an eye on the coolant level in the fill tank. I did have to add maybe another pint or so after the engine was warm.
I then pulled the funnel, replaced the cap on the fill tank and drove the car for a few miles to ensure the coolant was good and warm and circulating throughout the system.
I didn't really notice notice at that point that there was no heat. I was just happy that the coolant leak was fixed.
The next morning when it was 22 deg outside and I was driving into work was when I noticed there was no heat.
There is vibration from the heater pump and all of the electrical connections to the solenoid valve are made and correct.
I think I may have connected to output of the pump incorrectly to the solenoid valve and the pump in pushing against the check valve in the heater hose.
Can anybody post a diagram or a picture of the solenoid valve?
Old Dec 31, 2010 | 06:14 PM
Dan R's Avatar
I hope that this helps.
Old Jan 8, 2011 | 12:06 PM
  #30
pingj's Avatar
Thanks to the diagram Dan provided I was able to figure out I made a dumb mistake and connected two hoses incorrectly.
Swapped them and we now have heat.
Thanks Dan
Old Jan 8, 2011 | 12:23 PM
  #31
Dan R's Avatar
Thanks Dan
You are welcome. This is what the forum is for.
Dan
xjrjag
Oct 24, 2024 03:09 PM
hoodun
Aug 10, 2021 10:32 AM
thedugger1
Oct 16, 2015 10:18 PM
Philurusso
Sep 20, 2015 07:02 AM
scatcat
Sep 15, 2015 06:55 AM
