Mystery cold start rattle noise
Old Mar 22, 2021 | 09:53 PM
92/93 XJS's Avatar
Default Mystery cold start rattle noise
So, I'm scratching my head on this one. '01 base XJ8 w/ 150K had new tensioners done 3 yrs ago. Recently, I get what might be called a tensioner rattle on cold start-up. Rattle goes away within a couple of seconds and does not occur again regardless of the number of stop/starts on a drive. I'm told new tensioners don't go bad. Recent oil change had no effect. A club member suggested the VVT actuator is loose. The rattle is definitely in the left-front top of the motor.
Soooo, any guesses?
Dave in AZ
Old Mar 23, 2021 | 05:51 AM
RJ237's Avatar
The metal tensioner has a ratchet mechanism that keeps the foot extended when the engine shuts off. There was at least one report of this failing that I recall. So it might be worth the effort of taking the cover off to see if the tensioner is collapsed.
Old Mar 23, 2021 | 03:40 PM
92/93 XJS's Avatar
Thx for the lead. Wondering if this is an "engine fail" potential issue. Time and money prevent immediately addressing the problem.
Dave in AZ
Old Mar 23, 2021 | 08:02 PM
RJ237's Avatar
If the tensioner has collapsed it's possible for the chain to skip teeth, and that will result in bent valves. This may not be your problem but removing a cam cover is a pretty simple operation.
Were both primary and secondary replaced?
1 of 19
Oct 4, 2015 08:02 AM
wesmc2
Mar 10, 2015 04:03 PM
magnum454
Sep 5, 2014 05:53 AM
blackwolf560
May 3, 2012 04:50 PM
BigWill
Jan 12, 2008 06:09 PM
