Need help on Thermostat Housing 2002 xjr
Old Nov 19, 2008 | 01:34 PM
oldmots's Avatar
Default RE: Need help on Thermostat Housing 2002 xjr
Information from these services is copyrighted and cannot be reproduced on the website legally. Just get the service subscription, anyone that posts here should have one anyway, otherwise they are just plain in the dark as to the information needed to deal with the cars intelligently.
Old Nov 19, 2008 | 03:16 PM
chupacabra's Avatar
hi, i have a problem with my xj8 1998. a cooling system pipe that goes from the thermostat to radiator sometimes goes off with no reason, it just falls of and antifreese runs out... what could be the problem? thanks. ( sorry for my english it might be with some mistakes )
Old Nov 19, 2008 | 07:39 PM
Brutal's Avatar
chupa, replace the thermostat cover that that hose clamp to, and replace the thermostat while you have it off, but pop off the little ck ball on the top with pliers. It creates a vacuum on that hose when cooling down and sucks the hose off and the ribs on the cover wear down, you may want to replace that lower hose too if original
Old Nov 20, 2008 | 09:16 AM
chupacabra's Avatar
thanks lot BRUTAL !
Doug
Feb 27, 2019 01:31 AM
GordoCatCar
Jan 2, 2017 01:10 PM
Booskisjag
May 5, 2016 09:38 AM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
jehart49
Sep 12, 2015 05:36 PM
