need help w wiring
Old Nov 10, 2021 | 03:24 PM
goodwin3026's Avatar
Default need help w wiring
i was working on my 03 Xj8 about 6 months ago doing the fuel pump, i got it replaced and put back all the wires except these two and for the love of me can’t figure out where they went. any help would be much appreciated
Old Nov 10, 2021 | 06:59 PM
Addicted2boost's Avatar
In your second photo, this is where your 3 pin harness connects to. It plugs into a short harness that goes to the fuel tank lid. The other photos after the 3 pin, I have no idea where it goes. I looked around in the trunk of my wife’s 00’ XJ8 for that other connector but, I didn’t stumble on anything like yours. My recommendation is to leave the trunk unassembled and get the engine running and see what doesn’t work.
Old Nov 10, 2021 | 07:25 PM
Actually, I take my previous post back. In my 03’ SV8, this connector is under the fuel filler lid and just forward of the CD player on top of the wheel well.
That 3 pin connector might actually be the same as what’s pictured in your post. It’s hard to see but, it doesn’t plug into anything. It’s in the center of this photo and just up a bit.
Old Nov 10, 2021 | 10:17 PM
thanks, y’all definitely solved the problem but now i have a new one and that’s this second 3 but connector that i had originally plugged in now i’m wondering where this one went
before
after
Old Nov 10, 2021 | 10:42 PM
i’m starting to believe i didn’t plug in something w the fuel pump, that would explain why i have an extra wire. strangely enough i can’t hear the pump coming on with either wire plugged in which kinda seconds my suspension i just don’t see where anything would plug in inside the tank or out to be in the position the wires are in
Old Nov 11, 2021 | 05:23 AM
Check for a blown fuel pump fuse??
Old Nov 11, 2021 | 02:09 PM
unfortunately i already checked for that and mine were fine
jaehoonhan
Aug 14, 2021 03:44 PM
Darrenmb
May 30, 2021 01:08 PM
Yash swamy
Apr 7, 2020 09:22 AM
alabbasi
Feb 5, 2014 12:09 PM
