Need a source for correct valve cover gaskets '02 Vanden Plas
I bought a long sought after color combo Vanden Plas in blue zircon over ivory :0)
The valve cover gaskets are both leaking a small amount and I want to replace them.
I had ordered a set off the internet engineparts.com, but they did not fit correctly
Can anyone please give me a source of where I can buy a set of correct ones online?
The dealer has a set for $350, but I think that is a bit high.
FEL-PRO VS50724R {#VS50397} makes a set I use when I order from my local parts store. or (Rock Auto $17.53+shipping)
MAHLE (VS50397) makes a set that looks like the FEL-PRO but at about 3x's the price. or (Rock Auto $51.99+shipping)
Here a link where you can find the partnumbers: https://parts.jaguarlandroverclassic.../brand/jaguar/
Ealier engines have spark plug seals and center seals connected. Note: this is depending on engine production date, not VIN!
Engines with VVT need the additional valve seal (part 9)
Also note some sets do not include the center seals-
According to your pictures you need the gasket with seperate rings and the valve seal.
I just ordered my gaskets LH + RH from berkshire jag components.
AJ88285KIT-XJ8 (gasket + sparkplug rings) & 4x AJ87242-XJ8 (center seal) for 47,98 GBP (XJR does not have the VVT seal).
Dont know is they do shipment to US
I tried both, they both did not fit either valve cover. But yes, it did fit closer on the other valve cover, but not close enough.
Thank you for the info :0) This did help me.
I just ordered the $54 set from Rock Auto
ragman1171
May 24, 2016 11:30 PM
