No rear door courtesy lights
Old Jan 19, 2022 | 11:15 AM
3timejag's Avatar
Default No rear door courtesy lights
2003 XJ8- Neither of my rear door courtesy lights (red ones at corner of each door) are workIng. I’ve replaced the bulbs and can’t seem to find the correct fuse-if there is one.
Any ideas on this?
many thanks in advance!
Old Jan 19, 2022 | 11:22 AM
Addicted2boost's Avatar
I’ve heard that if you spray enough WD40 into the door latch that it’ll work it’s way into the micro switch to free it up. With the rear doors open, sit on a stool and with one hand (or a helper) keep the inside door handle in the open position while using a screwdriver to move the lock back and forth a bunch of times. The only other thing I know of is to replace the lock/latch assembly.
Old Jan 19, 2022 | 12:58 PM
3timejag's Avatar
Thank you sir! I’ll give that a try.
maniqz
Mar 29, 2017 01:47 PM
Salu498
Jul 18, 2016 10:20 PM
monz87
Oct 24, 2011 12:42 AM
jeffjames
Sep 30, 2010 06:15 PM
beatch
Nov 21, 2007 04:15 PM
