No tail lights
Old Nov 23, 2021 | 11:18 AM
  #41
xalty's Avatar
Originally Posted by Reddevil
Aint that a pisser! I didnt realize that was controlled by the other fog light switch! I feel stupid....nevermind then. Geez. Hkwever, the "check rear lights" stays on. I do have 2 bulbs out in the high center mount. Would that cause that display message?
it shouldn’t
i threw mine in the trash a long time ago
Old Nov 23, 2021 | 11:23 AM
  #42
Parker 7's Avatar
So by removing 2 of your bulbs of the 5 the total resistance should decrease increasing your current flow to keep the inop tail light message out
The inop message light should come on with lowered current flow . an example would be a burnt out light bulb filament
Just put in the number 5 ohms for each bulb as an exercise you would have 3 over 5 vs, 5 over 5
Old Nov 23, 2021 | 12:09 PM
  #43
Reddevil's Avatar
Originally Posted by xalty
it shouldn’t
All of the lights work...now. I did not replace the 2 burned out bulbs in the high mount yet. I cant get the cover off. Feels like its gonna fall apart. There is a crack in the black housing that attaches to the window. I do have the trunk light bulbs out, they are burnt. Will that cause the message?
Old Nov 23, 2021 | 12:12 PM
  #44
Reddevil's Avatar
Messing around back there did force me to redo the looms. It is not a tangled mess now. I like things tidy.
Old Nov 23, 2021 | 12:13 PM
  #45
Reddevil's Avatar
Originally Posted by Parker 7
Gotta get a Covid test lined up for a cancer surgeon Dr appointment tomorrow
So far non cancer in testing
Be well, and thanks for your help.
Old Nov 23, 2021 | 12:21 PM
  #46
Parker 7's Avatar
Fortunately I am well but a surgery has to be done and coordinating it with Covid symptoms and the testing before letting me into the building
Old Nov 23, 2021 | 12:27 PM
  #47
Parker 7's Avatar
The trunk light bulbs burnt out would definitely give you the inop message
Do not remove the high tail light assembly as it attaches to the glass
A pain to reglue
There are post on repairing the high tail light assembly
Old Nov 23, 2021 | 12:38 PM
  #48
Parker 7's Avatar
Maybe a pic of your broken high tail light assembly and maybe someone can identify the solution as the X300 may be different
Your light assembly repair would be a separate topic thread to start
I had the X300 off and can identify the difference if so
There was a good picture filled repair procedure for the X300 From Al R. that I saw before and can find later
NevadaXK8
Nov 23, 2021 12:37 PM
gatorVDP
Sep 6, 2019 12:01 AM
Nerobergstr
Aug 10, 2017 08:16 PM
Zane Cramer
Aug 19, 2013 07:59 AM
coastaljag98
Oct 15, 2012 10:19 PM
