Noise from front!
Old Oct 11, 2020 | 10:44 PM
mat32essex's Avatar
Default Noise from front!
I noticed there is a slight noise coming from the engine bay. It is not that bad but was just wondering what it could be. It is a slight ticking noise which can barely be heards over the engine. The oil has not been changed in a while as I do not use it much. Also, the oil they used last time it had a service was 10W-40 and afterwards I got told this is not the right oil for my car. It drives fine and no problems with acceleration and drives fine with no warning lights. I just got worried about it being a tensioner problem as I am not sure if the uprated tensioners were fitted to my car or not. Any suggestions would be greatly appreciated ?. I have enclosed a link for the movie file as I cannot uploaded it on here.
https://drive.google.com/file/d/1h3M...ew?usp=sharing
Old Oct 12, 2020 | 02:56 AM
anduha's Avatar
Sounds like normal valvetrain chatter. Usually a failing timing chain tensioner will have a more pronounced rattle, especially at startup. If you have never had the tensioners inspected or updated I would do it very soon. A 1999 would have plastic ones and they are going to fail at some point.
5w30 is the correct oil for these engines. Some people believe a heavier oil will slow wear but in reality as these engines operate in tight tolerances, a higher weight oil will not flow as well and may provide worse lubrication. Nothing catastrophic but I would go with the recommended oil.
Old Oct 12, 2020 | 07:59 AM
RA110623's Avatar
Banned
Owner manual show 5w40 in hot climate
Shadow993
Jun 9, 2025 07:35 PM
Miauuu
Sep 18, 2019 09:04 AM
Johnnyxk120
Jul 29, 2018 08:04 PM
MR. CJ
Sep 6, 2014 08:24 AM
XJ8JR
19
Jul 18, 2013 08:37 AM
