Noob here that needs help from you experts! PLS!!
Old Dec 16, 2009 | 06:49 PM
swift707's Avatar
Default Noob here that needs help from you experts! PLS!!
hello people,
Im new to the forum but I had my hand me down 2001 Vanden Plas V8 for a year now and Im loving it. Just a couple days back I noticed that whenever I turn off the car, 3 seconds later, the fan starts blowing. Now I was told that it's normal but why all of a sudden a couple days ago. I never experienced this with my car since I got it.
While I was driving today, I noticed after around 25 mins of driving, I can hear the fan sounding like its working harder than normal and my temp gauge almost reaching the red point but going up and down here and there.
Now I checked the coolant and it seems to be at the amount its suppose to be (lined up with the orange washer looking thing right)?
Im such a noob at this thats why im glad I found this board and asking you experienced in this department. I'm starting to educate myself so I can solve simple problems with the car. Thank you guys in advance!
Old Dec 16, 2009 | 07:45 PM
Markus's Avatar
Urgent that you replace the thermostat before you incur serious engine damage.
________
Old Dec 16, 2009 | 09:52 PM
Catmando85's Avatar
Cool
X2 very much agree
Old Dec 16, 2009 | 11:23 PM
swift707's Avatar
thanks guys for your input. so you mean to tell me its just my thermostat malfunctioning? I mean my car seemed to struggle when it almost hit red on my gauge. so its nothing under the hood? does that make sense? sorry i feel dumb right now.
Old Dec 17, 2009 | 10:49 AM
JimmyL's Avatar
Talking
The thermostat is under the hood. So is the waterpump. I replaced both when I got my 2001 VdP. The waterpumps have plastic vanes up to a certain point - I know mine did - and the new ones are metal. The plastic ones disintegrate and cause problems. They are easy to replace and not too expensive, but definitely worth the peace of mind.
Old Dec 17, 2009 | 11:00 AM
magilla's Avatar
Exclamation X3 It's the Thermostat!!!
Listen, it's the thermostat. Classic case of thermostat stuck closed, causing fan to run when it shouldn't. Jaguar built in a bypass, but it is not sufficient to handle long trips in hot weather. Your next indication will be droplets of coolant under the radiator, primarily coming from around the thermostat. After that, the rubber will eventually fail, or the plastic thermostat housing, and you will have a big time coolant leak.
Jag aluminum engines WILL NOT STAND AN OVERHEAT.
$25.00 and about 30 minutes total with a 10mm socket (three bolts facing you from the thermostat housing) and you're done. Spray some PBS blaster on the bolts and the bolt ends where they protrude on the other side, and wait about 10 minutes. Easy on teh wrench when loosening and tightening, or you could, (and may anyway) strip out the bolts. If you do - no big deal. Go to hardware store and get some 10mm nuts and 3 bolts that are about 3/4" longer, and bolt it together. It just takes a little more coordination and three hands to secure the bolts and nuts). just be careful with that plastic thermostat housing, and don't torque down when you tighten it back up, or else it WILL strip. You need only about 7 inch-lbs... Or "just snug" with a screwdriver handled driver with 10mm extension. You use a socket handle, and you will strip it.
Level of difficulty: 2
If you have some down time, and are experienced, I would also recommend changing the plastic thermostat housing to aluminum, as well as the water pump. Total investment: about $130.00, and you will be money WAY ahead.
However, at least swap the thermostat.
Oh yeah, and buy yourself a subscription to ALLDATA...
04Xjrsteve
May 7, 2019 04:06 PM
BoarHawg
Dec 14, 2015 12:21 PM
R-Sport
UK & Eire
Nov 17, 2015 08:33 AM
Sarc
Sep 29, 2015 08:28 PM
sonofdave1980
Sep 14, 2015 07:45 PM
