normal sunroof opening limit
Old May 3, 2011 | 03:15 AM
plums's Avatar
Default normal sunroof opening limit
Is the normal limit for opening the sunroof about 3 inches between the front edge of the sunroof panel and the rear edge of the sunroof aperture?
In other words, it does not fully retract until the panel edge is flush with the rear edge of the aperture.
Just fixed the wobbly tilt arm problem. Bad design. It looks as if it might be possible to swing the spring around to the other side of the arm to keep the pin from wandering out of the slider hole. If they had done it that way at the factory, it would never have fallen out.
edit: nevermind, finally found another thread answering the question by searching on "sunroof", "inches". The gap is normal.
abonano
25
Sep 25, 2015 10:43 AM
kabs3012
Sep 12, 2015 10:40 AM
kabs3012
US Midwest
Sep 10, 2015 01:17 PM
TexasCat
Sep 8, 2015 04:36 AM
King Charles
Sep 3, 2015 12:40 AM
