OBD codes P1216
Old Sep 7, 2013 | 01:23 PM
gieniukas's Avatar
Default OBD codes P1216
ive got codes P0170, P0206, P1216 and P1000 ,can somebody try explain me what exactly are ? I cant find any explain for P1216, and what i can do to fix it
Old Sep 7, 2013 | 02:04 PM
Maninahat98's Avatar
This might help.....regards, Allan
Jaguar Check Engine Light DTC Trouble Codes
Old Sep 7, 2013 | 05:59 PM
gieniukas's Avatar
Default Pedal Position Sensor C Circuit High Input
what it is means and how i can fix that , got 2000 xj8
Old Sep 8, 2013 | 06:15 AM
fredd60's Avatar
Default obd codes
P0170 fuel trim malfunction, bank 1
P0206 injector circuit malfunction, cylinder 6
P0216 injection timing control circuit malfunction.
I think you have a problem with the injector wiring, or a bad injector.
Seems to be driver's side, second from rear, but good idea to check all wiring.
It may be throwing in so much fuel that ECM can't compensate for it, and showing P0170.
Old Sep 8, 2013 | 11:00 AM
motorcarman's Avatar
Here is a copy of the Jaguar DTC guide for your car.
Lots of info on the internet about DTCs and repair.
bob gauff
File Type: pdf
Jpav27
Jul 31, 2022 06:43 AM
philwarner
25
Jun 26, 2021 05:43 AM
Will P
Sep 19, 2018 08:36 AM
KarimPA
Sep 27, 2015 08:46 AM
Bob Gelston
Sep 14, 2015 11:08 PM
