oil on spark plug what to fix?
Old Mar 17, 2019 | 06:12 PM
RA110623's Avatar
Banned
Default oil on spark plug what to fix?
I just pulled one of the engine spark plugs and found oil on it but the oil is not on the spark plug tip at all the til is dry. the oil was not much not like dripping oil but there was oil I'm really disappointed and dippresed I know it's not simple issue but not sure if it's head gasket I hope it's valve cover gasket or valve seals .
where to start ? how to idintefy the faliure part ?
Old Mar 17, 2019 | 07:11 PM
RJ237's Avatar
Do you have a XJ8 or XK8? If yes, I'm a little unclear as to what you're saying. Do you mean you have oil on the body of the plug above the threads? If so you need to replace the cam cover gaskets, including the spark plug seals and the seals for the screws.
At the top left of the page click on 'User CP'. Find the signature section and give the model and year there.
Old Mar 17, 2019 | 07:40 PM
Highhorse's Avatar
A pic or pics would be nice....but like RJ, my initial assumption (and cheapest) would be the cam cover gaskets....and yes, please identify your vehicle more directly in your signature to better assist us.
Old Mar 18, 2019 | 10:21 AM
RA110623's Avatar
Banned
it's xj8 I think I will change the valve cover gasket and the plastic camshaft tensioner.
Old Mar 18, 2019 | 02:34 PM
avern1's Avatar
While you have the covers off make sure you clean out the part load breather hose and the small orifice in the drivers side cam cover. Gaskets will fail with age but most of the time the failure is caused because of a partially blocked part load breather. The part load breather exhaust the crank case pressure to the throttle body. When the pressure builds up it will add to the cause of cam cover leaks.
Lagonia
Feb 12, 2022 11:18 PM
GvilleVDP
Jun 6, 2013 08:20 AM
Jag X-cited
Jun 25, 2012 06:48 AM
SteveJacks
Dec 7, 2011 06:50 AM
benebob
Sep 15, 2010 09:12 AM
