oil type and plug suggestions 98 xj8 4.0
Old Dec 17, 2008 | 05:22 PM
XJ ate's Avatar
Default oil type and plug suggestions 98 xj8 4.0
I gotta tune this thing up before I leave town for the holiday and want to change oil and plugs and filter.
I'm looking for oil weight and type (syn or not)
also does it need plat plugs (i usually use them in everything) Any brand you guys prefer over another?
thanks
Old Dec 17, 2008 | 11:17 PM
XJ ate's Avatar
Default RE: oil type and plug suggestions 98 xj8 4.0
Come on you all. I know some of you tune up your own cat, what do you use?
Old Dec 18, 2008 | 03:05 PM
hlgeorge's Avatar
I asked about spark plugs under XK8 & XKR and got no answer either. I guess no one has any plug recommendations!
Old Dec 18, 2008 | 08:28 PM
XJ ate's Avatar
I pulled one of mine yesturday to see if they needed to be replaced and there is ngk in it. I figure NGK Plat or Iridium or Bosch +2 will be the best for it.
I just wondering what kind of oil now.
I'm sure not all these Jag owners are rich enough to take the cat to the ******* everytime it needs an oil change, or maybe I'm the only broke one here.
Old Dec 19, 2008 | 06:13 PM
hlgeorge's Avatar
NGK were the original plugs. I was looking specifically for the NGK Iridium plugs. The NGK site does not list any for an 01 XKR, but do list them for an 01 XJR. I am assuming they should be the same.
xjrjag
Nov 27, 2025 09:16 AM
stanjag
Dec 29, 2024 08:26 PM
DavidNagel
Dec 29, 2017 09:16 PM
hawianjim
Aug 29, 2015 07:23 PM
Will P
Aug 27, 2015 06:52 PM
