Orphan plug under the hood, where should it plug in?
Old Jan 29, 2020 | 12:31 PM
roycej's Avatar
Default Orphan plug under the hood, where should it plug in?
Hello, I recently bought and started working on a non-running 1998 XJR. After timing chain and tensioner replacement, it's now running. , although not the way it should. I noticed in the engine compartment a plug which is not plugged into anything and for the life of me I can't figure out where it is supposed to go. I'm a newbie here and can't post pictures yet, but maybe someone can identify it by description. It's next to the firewall on top of the engine, right behind the purge valve. It comes up fro
m underneath right next the the wire that plugs into the purge valve. It's only about six inches long, and I just can't find anywhere nearby that looks like it should plug into. Any help would be greatly appreciated. Thanks,
Old Jan 31, 2020 | 10:06 PM
Highhorse's Avatar
I'm not sure about the AJ26's, if they came with a MAP sensor?
Old Feb 1, 2020 | 08:53 AM
M. Stojanovic's Avatar
The connector is for the (missing) accelerometer which bolts to the two vacant studs. If your original CATS shock absorbers have been replaced with non-CATS ones, you don't need it.
Old Feb 1, 2020 | 09:20 AM
roycej's Avatar
That's it, thank you very much. I have no CATS, so no worries.
Darren9090
Dec 15, 2016 08:59 PM
orangeblossom
May 22, 2016 09:12 PM
grogers1
Jun 18, 2014 02:47 PM
bogart
Nov 23, 2010 04:55 PM
TN8Shooter
Oct 20, 2010 09:13 PM
