Overheating 🥵 Help
Old Jul 3, 2020 | 12:45 PM
Redmazda's Avatar
Today had fitted new water pump new thermostat and still engine overheating and no fan working
Old Jul 8, 2020 | 10:32 AM
Redmazda's Avatar
Garage has also found that the Heater pump has a problem so they said they have bypassed it for now but will the heater pump cause engine to build up pressure and boil over
Old Jul 8, 2020 | 10:49 AM
Jhartz's Avatar
Go back to #12 and #14 and confirm these lines are correct. Then remove the cap on the fill tank and check for bubbles as the engine is running. Any good shop should be able to check for exhaust gases in the coolant and determine why the fans are not coming on.
Old Jul 8, 2020 | 05:57 PM
Addicted2boost's Avatar
To answer your question Redmazda, no, even if the electric water pump for the heater Is seized, it will not cause your engine to overheat.
If they replaced the blown fuse and it blew again, then chances are there’s a shorted out fan motor.
Is this a Jaguar car? Yes. Is this a complex cooling system? No! It’s no different than most other vehicles.
I'm beginning to have second thoughts about this shop..... it’s not that difficult...
Old Jul 10, 2020 | 01:28 PM
Redmazda's Avatar
I’ve decided to sell the jag it’s had new water pump thermostat and car runs great it just has this problem of heating up if left to idle so if anybody fancies a bargain make me a offer car is mot till December hope somebody can sort her out and keep her going
andyzeg
Apr 25, 2019 06:35 AM
LondonXK8Boy
Sep 29, 2014 09:32 AM
FreakingAwesomeJag
Mar 7, 2014 11:56 AM
ExKay8
Oct 21, 2010 12:23 PM
Paul_b
Jul 17, 2010 09:50 AM
