Oversized Valve shims
Old Apr 30, 2013 | 11:01 AM
dsnyder586's Avatar
Default Oversized Valve shims
Anyone know where I can source oversized valve shims?
I need a couple that are around .112-.117
Alternatively ANY ideas short of R&Ring the head?
Old Apr 30, 2013 | 02:19 PM
sparkenzap's Avatar
Of course, the deeper you lap or grind the valves or seats, the less shim you need. I will check the ones I have, but I am thinking 2.4 mm is about the largest I have.
Old Apr 30, 2013 | 05:45 PM
dsnyder586's Avatar
I just don't want to spend the time pulling the head, but if I cannot find the oversized shims it will be my only option.
Old Apr 30, 2013 | 06:22 PM
Jaguar list shims individually from 2.18mm to 2.90mm in 74 incremental thicknesses.
If you only need a couple at around $15 each ( ), it has to be a better option than a tear down.
Old Apr 30, 2013 | 07:09 PM
dsnyder586's Avatar
That would bring one within .003 and the other would be spot on. Hmm. Maybe that would work..... It would certainly be quieter at least.
Anyone made their own valve bucket tool?
Old May 1, 2013 | 06:40 PM
dsnyder586's Avatar
Picked up a couple of the largest they had at the dealer- 2.90mm and it quieted down ALOT. It's now bearable to drive and should be for the foreseeable future.
Thanks!
hoodun
May 15, 2019 09:31 PM
hoodun
Oct 6, 2015 08:34 PM
Johncy2000
Oct 2, 2015 01:05 AM
jjmiah217
Sep 28, 2015 09:09 AM
