P1121, before you replace that throttlebody
Old Mar 30, 2014 | 09:05 AM
motorcarsrandy's Avatar
Default P1121, before you replace that throttlebody
My 2000 XJR went into restricted performance mode and had a pending p1121 code. My first response was a bunch of expletives I cant use here. I figured a Theottlebody was in my future.
I decided I would look around. It appeared my TPS connector was not fully locked . Disconnected connector and look at TPS pins with a mirror. Behold i find corrosion on pins. Cleaned terms with terminal tweezers and contact cleaner. Behold, no more issues.
What made me suspect was that it happened in very high humidity/rain situation on cold starts.
Look before you leap....(no pun intended)
Old Mar 30, 2014 | 05:16 PM
grandell's Avatar
It's also caused by the pins on one plug being gold, and the other plug being tin, so they corrode because of the different metals.
If the clips on your TPS are broken, like mine were, a cable tie around the whole assembly makes it nice and secure, and I've had 3 months of trouble free motoring since.
Old Mar 30, 2014 | 06:43 PM
WaterDragon's Avatar
And use a little bulb grease
This tip form some other board member worked for me.
Forcedair1
Sep 8, 2025 01:57 PM
RoyLittle0
May 25, 2023 02:38 AM
KarimPA
Sep 12, 2015 08:15 AM
Wes Steenrod
Sep 6, 2015 06:52 PM
KarimPA
Sep 3, 2015 07:32 PM
