Part Load Breather
Old Jan 18, 2010 | 05:19 PM
skatsuf's Avatar
Default Part Load Breather
My 99 wouldnt start so I had it towed to the local dealer. After much cranking they got it started . They said the part load breather was clogged. Also recommended installing a new fuel filter, cleaning the fuel injectors and throttle body. They want $700 for this. Is it
necessary to have all this done at once. ? Big expense for me now. Any comments would be welcomed.
Car has 42,000 miles on it.
Old Jan 18, 2010 | 07:10 PM
Markus's Avatar
Fuel filter @$20; clean part-load breather - 5 minute job; fuel injector cleaner - $8; do it all yourself - all simple, save $672
________
Old Jan 18, 2010 | 08:32 PM
StrateLoss's Avatar
Yea, if the car is starting on its own I recommend taking it home and doing the work yourself. The partload breather you can either replace for cheap, or clean it using throttle body cleaner ($5). The fuel filter is cheap and is fairly easy to swap as well, depending on your model.
The injectors you can run a bottle of techron injector cleaner ( I doubt they were going to take each injector off and have them cleaned the proper way ).
While you are at it take the time to clean your throttle body, and maf too. total cost will be around $40.
Old Jan 18, 2010 | 09:44 PM
SoTxXjr's Avatar
Can't vouch for the quality, but you can get a fuel filter at AutoZone for $10. Be sure to de-pressurize the system first, though. The rest of it is pretty simple. You can download a step-by-step of the throttle body/part load breather/MAFS cleaning here:
http://www.mediafire.com/file/jvnmhz...Clean_MAFS.pdf
Even if you needed a new part load breather hose, that's $35-$40, though a little more involved to replace (30 minutes instead of 5 minutes). I'm rarely shocked by dealer prices, but $700? Wow!
Old Jan 19, 2010 | 03:37 AM
$700 owch!! Are they taking the engine out, in order to do this on the bench?
And here is another link to the same document.
http://www.maxperformancecars.com/dm...Clean_MAFS.pdf
Old Jan 19, 2010 | 06:20 PM
Markus's Avatar
The factory-installed fuel filter on my XJR was a GM part (!) I have used Napa Gold replacements since - work fine. Techron is great stuff - nice link on the throttle body, guys - thanks!
________
aholbro1
Dec 29, 2024 06:46 PM
Bcrary3
Feb 21, 2023 04:29 AM
TXJagR
Jun 20, 2016 01:02 PM
perfectson
Nov 1, 2015 10:46 AM
nitrolouie2142
Sep 5, 2015 01:55 PM
