Plug Gap - OK, which is it?
Old Jul 31, 2011 | 09:57 PM
kenncl's Avatar
Question Plug Gap - OK, which is it?
99 XJ8, I have seen both .39 and .52 as the spark plug gaps. I am trying to quell some hopefully upstream problems.
Which is it, enquiring minds want to know ?
Old Aug 1, 2011 | 05:43 AM
test point's Avatar
According to JTIS the gap specifications for a '99 are:
Normally Aspirated 1.0 - 1.1mm (0.039 - 0.043 inches)
Supercharged 1.2 - 1.3mm (0.047 - 0.051 inches)
Old Aug 2, 2011 | 07:31 AM
kenncl's Avatar
Default :Plug Gap
Looking back,it was .43 not .39. Many source are quoting .52 but I will go with what the fine folks at the Jag forum.
Old Aug 2, 2011 | 04:33 PM
wazari's Avatar
TSB 303-29
DATE
9/98
V8 XJ Series/XK8
MODEL
1997 MY-ON XK8 Range
1998 MY-ON V8 XJ Series
VIN
001001-ON
812256-ON
Idle Quality - Spark Plugs - Revised Gaps
Issue:
The specification for spark plug gaps on all V8 engines has been revised to improve engine idling quality.
Action:
When installing a set of spark plugs check, and if necessary, reset the gaps to 1.3 mm (0.052 inch) before installation.
This policy applies only when a set of spark plugs is replaced at a routine service interval, or as the result of a customer complaint. Do not remove or replace existing spark plugs just to increase the gap.
SERVICE INTERVAL - V8 ENGINES
Normally aspirated 100,000 miles
Supercharged 60,000 miles
Warranty Information:
This Technical Bulletin is issued for information only.
Old Aug 2, 2011 | 07:02 PM
test point's Avatar
That TSB would apply to the AJ26 engine. Does it apply to the '99 AJ27 in question?
Old Aug 2, 2011 | 10:44 PM
wazari's Avatar
yes
boiler
US Southwest
Dec 20, 2025 12:38 AM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
mat32essex
Oct 3, 2015 04:12 PM
hoodun
Oct 2, 2015 02:06 AM
