Is it Possible to remove timing cover without
Old Nov 27, 2013 | 07:23 AM
osyris's Avatar
Default Is it Possible to remove timing cover without
1999 x308, non supercharged.
Hello , I have the balancer pulley off to fix the oil seal , and recall oil leaks from the right side of the timing cover somewhere AND from underneath the pulley located in the "V" section Valley between the 2 camshafts in the middle top of the timing cover .
Im assumming this leak is also emanating from the timing cover gasket in that V section..... could it be anything elsein that area ?
Im not so sure hat applying some gasket sealant externally will fix any of these leaks, so im considering redoing the entire timing cover.
As such, I was wondering if its possible to remove the timing cover without removing the cam covers to fix these leaks.
best regards
Peter
Old Nov 27, 2013 | 09:43 AM
dsnyder586's Avatar
I suppose it is possible, but I would replace the cover seal along with the cam cover seals to make sure all the potential leaks were addressed.
SD96XJ6L
Jan 12, 2022 04:30 AM
RaceDiagnostics
Dec 11, 2015 10:12 AM
Beardy
Sep 18, 2015 10:00 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
Bcrary3
Aug 31, 2015 11:29 AM
